DroneFlying
Flight distance : 10774613 ft
Assuming that you have disabled it explicitly or implicitly (e.g., by using Sport mode), the front OA distance will be shown in the Go app when you're close enough to something to trigger it. If you aren't seeing that then you need to make sure it's enabled, and if you're sure it's enabled but it still isn't working then you should contact DJI. |
