DJI Thor
Flight distance : 13602 ft
Hi sir, I am sorry for replying in English. So you mean now you are not able to change the camera settings to 4K 30fps, right? First, just to clarify, 30fps is only available in resolutions below 3840×2160, so please ensure that you have chosen the right resolution. If you are choosing right, please check if there is an error code in the app, try to do a camera set.
Also, would you please try to use the original SD card which came with the drone and see will it be able to change.
If steps above doesn't help, could you please provide me with the video of this case as well as the screenshot of the firmware info page? Here is the route: power on the drone, RC, app and enter device---upper right icon---general----about.
Thank you so much.
