hallmark007
Flight distance : 9827923 ft
Flying at night is fine, don’t know what your countries rules are so check these out first, you can see the light from your spark for probably 200 metres , so try to get as close as you can to what you intend to film.
The area you launch from should be well lit or you might have a problem with drift because VPS won’t work properly in bad light, but apart from that and no OA your Aircraft should be ok just make sure you have enough satellites and you have recorded homepoint and your RTH is set as it should be.
Look forward to seeing the photos. |
