Spencer0787
A CW Posted at 2017-12-29 03:53
In answer to your question In terms of live feed only - the Mavic series uses ocusync tech which in my experience is better than lightbridge on the P4P - less drop outs and glitches and better range. Also, if you shoot in 2.7K on the Mavic (not 4K) you can set the live feed to 1080p FHD whereas the live feed on the P4 series is only 720p HD. The quality of the live feed will also be effected by the device you use. A modern iPhone (7+, 8+, X) will be better, for example, than an old Android device. That said, the image quality from the Micro SD card will obviously be superior than the live feed and the P4P and P4A has a better camera than the Mavic. The camera on the Mavic and Mavic Platinum is officially the same but again, in my personal experience, the image quality is better on the Platinum than the original MP. So - get a Mavic Pro Platinum edition with an iPhone 7+, set the live view to 1080p FHD and you won't be disappointed.
Exactly what I was wanting to know, thank you for the detailed response |
