DroneFlying
Flight distance : 10774613 ft
It's hard to say how common that is given that most people never check or comment on it that I've noticed, but my Mavic Pro (not Platinum) has displayed green on both when I've checked. The screen capture you provided seems to show your Mavic sitting on some kind of man-made surface; do you also get the same results when you put it on bare ground? If the results are different then it's likely that what you posted was the result of interference by some metal nearby, possible something embedded within the surface on which it was sitting. Other than that I only recall this happening when someone has something (e.g., a tracking device) attached or -- less frequently -- when the gimbal pitch is at an angle that affects a compass. |
