polletttim
Flight distance : 7572 ft
Alexei Merinov Posted at 2018-1-4 22:22
if you have tried everything that colleagues recommend above, try to identify the two sources of the problem:
1. There is no freedom of rotation of the gimbal elements. Try (turn off the power) with your hands, without effort, repeatedly rotate the camera along all axes. It should rotate freely from the stop to the stop. If you notice any friction - in the service center.
2. The propeller is unbalanced. In turn, leave one propeller, turn on Mavik and touch the body with your finger. Try to estimate the vibration, just adding the speed of the motor. If you find a heartbeat, change the propeller.
it does move freely along all axis' but it springs back on the 'horizontal axis' when I let go - I was wondering if it was supposed to spring back slightly towards to gimbal arm or if that is an issue. it centres itself when the drone is turned on. I can upload a pic or vid of it just to make sure I guess.
I like that idea about the unbalanced propeller. In my opinion, I think it is a propeller issue (maybe I've convinced myself) so I'll try that soon! I'll have to try it in the heat and in the cold.
