4.1.15 - Android Turning off Video saving to phone
1487 3 2018-1-13
djiuser_IvjZ0Kb
I am staying on 4.1.15 because of OTG.  Is there any way to disable saving to phone on this version?  I rather use the bandwidth for video transmission.  I feel like when I am recording, signal disconnects a lot.
2018-1-13
Wachtberger
Flight distance : 261509 ft
You can try to set "Largest Video Cache Capacity to zero or lowest possible value (I have never tried to go below 2G but believe it should be possible. And then also de-activate "Auto Video Cache Cleanup". This way you should achieve the effect desired by you. But I am not convinced that your problem is related to that. And what do you mean when writing "when I am recording"? Recording on the SD card in Spark should have no influence either.
2018-1-13
vudiesel
Wachtberger Posted at 2018-1-13 16:46
Good thinking.  Never thought about doing it that way.
When I start recording, I get frequent "No Signal."  When I am flying without recording, for the most part, I don't get the No Signal.  I am thinking if it is video caching to the phone, it is taking up bandwidth.  I am going to test your suggestion and see if the "No Signal" pops up.
2018-1-13
Alex B.
Flight distance : 21105262 ft
aamir786 Posted at 2018-10-6 04:33
November 2018 calendar PDFNovember 2018 calendar PDF November 2018 calendar PDFNovember 2018 calendarPDFNovember 2018 calendar PDFDecember 2018 calendar PDFDecember 2018 calendar PDF December 2018 calendar PDF November 2018 calendar PDFNovember 2018 calendar PDFNovember 2018 calendar PDF November 2018 calendar PDFNovember 2018 calendar PDFNovember 2018 calendar PDF November 2018 calendar PDFNovember 2018 calendar
DUDE DO US ALL A FAVOR AND JUST GET LOST MAN!!!!!
Or else someone will call a hacker attack on you
Fly safe
Alex
2018-10-6
