Spar
Flight distance : 19879 ft
DJI Susan Posted at 2018-2-9 02:08
Spar, it seems that the update is still not successful. Please try to format the SD card and update again. If no luck, please export the upgrade log for analysis. You can find it here: SD card>MISC>Log.
Regarding the RC issue, turn off the RC, hold C1+C2+Record Button+ISO Dial, then turn it on again to connect the APP and update from overall status.
Result: Success.
========== 2014.01.01 00:00:31 remo-con disconnect======
Packet: P3X_FW_V01.02.0006.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.06.17 13:56:36 =====================
Result: Abort.
========== 2015.06.17 14:04:39 =====================
Result: Abort.
========== 2015.06.17 14:21:01 =====================
Result: Abort.
========== 2015.06.18 11:08:49 =====================
Result: Abort.
========== 2014.01.01 00:00:14 remo-con disconnect======
Result: Abort.
========== 2015.06.20 14:30:52 =====================
Result: Abort.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
========== 2014.01.01 00:59:01 remo-con disconnect======
Result: Abort.
========== 2015.07.11 10:29:51 =====================
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.07.25 16:21:27 =====================
Result: Abort.
========== 2014.01.01 00:12:47 remo-con disconnect======
Result: Abort.
========== 2015.08.09 17:16:03 =====================
Result: Abort.
========== 2015.08.10 16:51:42 =====================
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3X_FW_V01.02.0006.bin, P3X_FW_V01.03.0020.bin
Result: Forbidden.
Multiple version firmware bin files are detected. Please delete the redundant bin file.
Result: Forbidden.
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
Result: Success.
========== 2015.08.16 13:47:14 =====================
Result: Abort.
========== 2015.08.22 17:54:01 =====================
Result: Abort.
========== 2015.09.05 08:15:52 =====================
Result: Abort.
========== 2015.09.06 14:17:50 =====================
Result: Abort.
========== 2015.09.06 14:21:08 =====================
Result: Abort.
Result: Abort.
========== 2015.09.21 15:45:24 =====================
Result: Abort.
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
========== 2015.11.08 07:18:45 =====================
Result: Abort.
========== 2015.12.13 16:49:50 =====================
Result: Abort.
Packet: P3X_FW_V01.06.0040.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Upgrading ...
========== 2015.12.28 09:10:22 =====================
Upgrading ...
Packet: P3X_FW_V01.05.0030.bin
Upgrading ...
Result: Success.
Result: Abort.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.07.0060.bin
Upgrading ...
Result: Success.
Packet: P3X_FW_V01.08.0080.bin
Upgrading ...
Result: Success.
========== 2016.06.05 13:58:13 =====================
Result: Abort.
Packet: P3X_FW_V01.11.0020.bin
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
