How do I do this update? Does not leave 0%
743 15 2018-1-16
ZmaroSobrinho
Flight distance : 7058809 ft
Brazil
I have samsung s7 edge. Every time I enter the dji go I get this message that you have to update this. However, clicking to update the app tells you that there is no internet connection. So I disconnect the wifi from the control and connect to a local wifi with internet and even then the progress stays at 0%. I already tried via cable otg, with data network and in no case it authenticates. Does anyone explain to me how to proceed?
2018-1-16
Wachtberger
Flight distance : 261509 ft
Do it with DJI Assistant: https://www.dji.com/spark/info#downloads
2018-1-16
ZmaroSobrinho
Brazil
Wachtberger Posted at 2018-1-16 15:39
thanks. I looking there, but there is no information about this, just firmwares. I will try reload firmware
2018-1-17
Wachtberger
ZmaroSobrinho Posted at 2018-1-17 01:49
On the right side of the download page you will find DJI Assistant for download on your PC or Mac.
2018-1-17
A CW
Flight distance : 13978875 ft
How do you update the precise fly database with DJI Assistant 2? I thought this could only be updated when the request to update pops up in the app whilst the drone is turned on and connected.
2018-1-17
Wachtberger
A CW Posted at 2018-1-17 02:39
I have done it once so far and I got a window popping up in DJI Assistant for the update.
2018-1-17
A CW
Wachtberger Posted at 2018-1-17 02:44
Well I never knew that - thanks for the info.
2018-1-17
ZmaroSobrinho
Brazil
where i update??? i alread refresh  firmwawre and still show message. where i go?? what i should do?
2018-1-17
ZmaroSobrinho
Brazil
and i alread click on restore factory default too
2018-1-17
ZmaroSobrinho
Brazil
and no one message show
2018-1-17
Wachtberger
ZmaroSobrinho Posted at 2018-1-17 13:26
[view_image] where i update??? i alread refresh  firmwawre and still show message. where i go?? what i should do?
If you are only getting this screen, there is nothing else you can do. For me a while ago a message for Fly Safe Database update popped up automatically and I did it that way.
Are you still getting the update message when connected with your mobile device?
2018-1-17
ZmaroSobrinho
Brazil
Wachtberger Posted at 2018-1-17 13:31
I'm still getting the message. I've tried everything I have in this program and it did not work. It will not work on the phone. I'm thinking of borrowing an iphone and try
2018-1-17
Wachtberger
ZmaroSobrinho Posted at 2018-1-17 23:27
Good luck! I hope you can solve the issue.
2018-1-17
A CW
Yes, it works perfectly with me using IOS. Give it a try and good luck.
2018-1-17
ZmaroSobrinho
Brazil
A CW Posted at 2018-1-17 23:47
on iphone 7 no one message kkk. I will reset my phone and try again
2018-1-18
A CW
ZmaroSobrinho Posted at 2018-1-18 09:59
Make sure the phone is on the latest IOS 11.2.2 and reboot the phone THEN install the latest version of GO 4 from the app store THEN turn on the drone and do not pass the screen with the drone on it as that is where the update instruction will pop up. If nothing appears after a minute then enter the first person camera view within the app, bring up general settings and tap 'about' - this will list all of the versions that your drone is currently on including firmware and the precise fly database.
2018-1-18
