not stable in P mode, rocks back and forth
633 6 2018-1-29
daveness
I have a new Inspire 2 with the X5S camera.  In going forward in P mode it rocks forward and back.  Aside from this being wrong it also makes the flight slow.  Side note, the gimbal works well even so.  It is as if it is in oscillation, in other words, that the control loop can't settle down.  Like it over powers and then over compensates.  In S mode this problem does not occur.  I took a quick cell phone video showing the rocking.  Any ideas?
Link to video of it rocking in P mode:
2018-1-29
epicjib
Flight distance : 3016060 ft
Have you did a IMU calibration? I would reinstall the firmware, reset back to factory settings, do a fresh IMU and compass calibration.
2018-1-29
daveness
epicjib Posted at 2018-1-29 09:03
Thanks Epicjib, I'm on a trip and don't have the usb to usb cable I need to update aircraft firmware via computer.  I tried used go 4 ap but I didn't see how to reinstall firmware that method.  I'll have to do this tomorrow evening when I return.
2018-1-29
RichJ53
Flight distance : 1837356 ft
Definitely recalibrate your IMU and Compass
to refresh your FW version using the DJI Go 4 App please use this video as a guide. You do not need to downgrade as the video shows, just pick the FW version you are currently on and it will refresh the same version.  before hitting the start button for refreshing, connect your inspire 2 to your device. Make sure your batteries are charged %100 before starting
Rich
2018-1-29
daveness
RichJ53 Posted at 2018-1-29 10:02
Epicjib and RichJ53, thanks much for your help.  That did it.  I downloaded new FW, did an IMU cal and a Compass cal and it worked great.  Note to anyone who does this, I found I had to power down both aircraft and remote control and then repower.  Instructions probably said this but I learned the hard way when it flew out but wouldn't turn around.  RTH brought it back.  Thanks guys, much appreciated.
2018-1-29
RichJ53
daveness Posted at 2018-1-29 14:27
Great....  I am glad you got it back up and running correctly.  Yes, anytime you finish FW updates on the aircraft, they need to be restarted.
Have fun on your trip and maybe you can share some of your video or photos with us when you return
Rich
2018-1-29
It seems I'm late here, glad to know Epicjib and Rich have helped you out, well done, hope you enjoy your trip.
2018-1-30
