RandomMistakes
I have a Note 8 which fits fine in the controller grips, but I have a problem with the included OTG cable. I noticed that on the USB-C OTG cable, the 90 degree rubber connector on the phone side is slightly wider than the same connection on the other adapters. This is a slight problem because it does not fit into the sliding plastic tray on the controller grip/clamp. It's not a huge problem, but it means I have to fiddle with the cable quite a bit to get the phone locked in place.
Anyone else have this issue, or did I just get a slight defect in my USB-C cable?
