DJI Thor
Flight distance : 13602 ft
Just to verify, did you fly the drone in a place with GPS signal? The top altitude here means the max takeoff altitude when you take off the drone. If the altitude is equal or less than 0, in iOS device, it will display 0, for Android device, it will display negative. You can try to sync the record or try to reinstall the latest app (note to back up the records and files on editor before uninstalling it). Hope it helps. |
