Nigel_
Flight distance : 388642 ft
MartinRJ Posted at 2018-2-21 13:55
This was the first time this happened: http://www.phantomhelp.com/LogViewer/H6L7E0USCIFWCPEJYF2B/
It started with "Magnetic Filed Interference. Exit P-GPS Mode; Yaw Error"
and then it said
The problem there is that you took off too close to some metal, maybe a car, underground pipes/cables, a cast iron grid?
Once you got to 15m height you left the magnetic field of the metal and the roll and yaw become inaccurate and the aircraft is unsteady, it dropped into atti mode for a while because the compass data didn't match the gps data. |
