turkus.csaba
Hungary
ho i have had a twitching gimbal and was told to reinstall the gimbal software but not really how to do it but will give you what i know ....
Technical Problem
Subject: H3-3D Reset
So these are the instructions for resetting the H3-3D:
1. connect the 2 dots in the picture attached using tweezers.
2. power on phantom
3. remove tweezers when you see red and yellow LED on together.
4. connect to assistant software to re-upgrade
This should reset the H3-3D and cure the twitching problem.
there are a few software assist programs so make sure you get correct ones
http://www.dji.com/product/phantom-2/download
for the gimbal go here
http://www.dji.com/product/zenmuse-h3-3d/download
from here your on your own as im still trying to get step by step guide to rest back to factory set
hope it helps
H3-3D
H3-3D |
