Linuxglobal
Flight distance : 380121 ft
Pics dont seem to show up, try re-loading. Try searching ebay for a scrap unit or may be lucky to find just the arm. You may cause more damage in the swap so if it works, might be best left alone.
Also as a heads up, to properly bend aluminum back, remove it from the gimbal, and use a heat torch, allows the metal to soften.
But all electronics need to be removed.
Not sure if it uses the same logic as the x3, but the x3 uses magnets in the motors for calibration, you may have moved one out of place in the drop.
