Sparky_17
Flight distance : 62349 ft
So are the lines and bars appearing on your device screen or on the images found on your SD Card? If they are appearing on your SD Card, have you tried a different card making sure it's compatible with high resolution images (Type 10 or higher). Secondly, try a lower resolution and see if the problem persists. if it does, then it could be the card, if it doesn't then it's definitely the wrong type of SD Card. |
