Gimbal issue...inverts screen
740 5 2018-3-7
fans80a6f87c
Flight distance : 711926 ft
Any one have issues when flying using c1 or c2 to tilt gimbal all the toward the ground that is inverts your screen? This has happened multiple time on my obsidian. Even when I manually move gimbal all the way down it still inverts my screen on my iPad. Anyone have this issue?
2018-3-7
djiuser_KB8ofpRAB9iy
Flight distance : 23875 ft
it's the new firmware, revert back to the old on for the drone till DJI fixes it.
2018-3-7
DJI Thor
Flight distance : 13602 ft
Hi there, the newest firmware just released hours ago, please update to the latest version to see if it is resolved.
2018-3-8
djmokoia77
Flight distance : 451627 ft
I've been having the same issue. Noob question - how do I roll the firmware back?
2018-3-8
Aardvark
Flight distance : 384432 ft
djmokoia77 Posted at 2018-3-8 08:02
Best to update to the latest version released today, that should address all the issues the previous build had.
Phantom 4 Pro/Pro+ Release Notes
http://www.dji.com/phantom-4-pro
Copyright © 2018 DJI All Rights Reserved.                      1
Date : 2018.03.08 Aircraft Firmware : V 01.05.0600 Phantom 4 Pro Remote Controller Firmware : V 1.4.1.0 Phantom 4 Pro+ Remote Controller Firmware : V 1.3.6.0 DJI GO 4 App iOS : V 4.2.6 DJI GO 4 App Android : V 4.2.6
What’s New?
 Optimized photo color and contrast.
 Fixed an issue that occasionally caused flipped live view when the aircraft braked during flight.
Notes:
 Restart the aircraft and remote controller when the update is complete.
 If the firmware update fails, restart the aircraft, remote controller and DJI GO 4 app or DJI Assistant 2, then try updating again.
2018-3-8
djmokoia77
Thanks, only just seen this.
My controller firmware version is reporting as v01.03.06.00 and when I check for update it says Latest Version Now
I've also tried connecting to DJi assistant and it doesn't give me the option to do a firmware update there either.
I've just updated the aircraft firmware to 01.05.0600
so based on this I should be good to go now...
2018-3-21
