ben.eidem
Flight distance : 1217 ft
It is forecast to be a bit warmer today so I'll test fly it again soon. This problem is even occurring in a low, approximately six foot hover, antennas pointed at the sky, with the aircraft only ten feet away or so horizontally. The latest firmware is installed, the GO app is the latest from the Google Play store. I've contacted DJI support in which we tried downgrading and re-upgrading the firmware, but yielded same results with both versions. I've flown in 4 different sites, one of which still had the problem but flew longer before beginning to lose signal.
To make sure we're on the same page with the battery, I've tried to take the drone outside, and turn on the motors so that the battery does not cool down. I sit at idle on the ground to time how long before I lose signal. If I'm unable to regain signal by bringing the remote closer, then I had to turn off the battery (not remove it) while the propellers are still spinning.
This is happening with both of my remotes, even after re-linking them as the master.
I bought the system new from B&H in New York, one of DJI's partner retailers. My friend who also owns an inspire will fly with me hopefully today to try his aircraft on my remote, and his remote on my aircraft, to see if we can further determine a likely cause. |
