thegrinch77
Flight distance : 2412513 ft
I experienced a lot of compass /gps failures the first weeks after I got my Spark.
Getting a compass failure under flight is really scary. My tips in this situation are:
1.Stay calm.
2.If the Spark starts drifting fast pull the stick up and gain some altitude. It will be much easier to guide the Spark home this way. The Spark often behaves weirdly when this error occurs, so additional height will buy you some time to figure out how to maneuver your little bee back home.
If the Spark wobbles on the same spot, or drifts in a circular pattern, breathe slowly. Usually, the Spark will re-aquire compass fix/Gps lock within 15 seconds or so.
3.If you experience compass failure, you should immediately calibrate the Spark compass, outside in a wide open area. Dont wear any metal objects and stay away from power lines, cars etc. while doing this. This solved all the problems with my Sparks compass/gps.
If this doesn't help, contact dji Support, they are really helpful! |
