Black Screen on App (Phantom Vision 2)
2226 5 2015-5-5
marinedgardo
Costa Rica
Hi I have a Phantom Vision 2 (not plus), one month ago the screen on mi iphone 6 turn black and i rebinded the camera and doesn't work.
I read on some thread, that the problem is the WIFI module, I checked the ip on my iphone, and the router IP is not there.
But my question is, is compatible the wifi module of the phantom vision PLUS on my phantom, because I read that is not.
Also I wrote 3 times to the DJI support but they doesn't respond me.
Someone know if this part is compatible with my unit, thanks.
The Serial number of the camera is:
FC-200 FCC ID SS3-FC2001307
AL021352517775
An of the WIFI extender:
MAC ADDRESS: 60:60:1F:60:2B:1C
FCC ID: SS3-RE5001307
SSID: Phantom_602b1c
AK291613279443
2015-5-5
johnwarr
Flight distance : 6467 ft
To answer your question, no the V+ Wi-Fi is not the same and will not work.
On the Vision the Wi-Fi module is built into the camera housing.
Before you rush off and buy anything I would run through the connection process again with a different phone or tablet.
Also you need to make sure you are fully updated with all the firmware for the Phantom, Camera, and App.
2015-5-5
umpa
I know people use the vision+ extender (RE700) with the standard vision to get more range. The vision has a RE500 extender. I am not sure if they modify any part.
2015-5-5
marinedgardo
Costa Rica
johnwarr@live.c Posted at 2015-5-6 04:23
On the Vision the Wi-Fi  ...
Thanks
Yes I updated the Phantom, and the phone, I tried to connect and reblind with two differents phones and the result is the same.
When I connect and check the ip's the router doesn't show in the info.
Thanks
2015-5-5
roy
When you bind your unit and put in the MAC address which mac address are you using. The one on the WiFi extender or the one on the bottom of the quad. Use the quad's MAC address.
2015-5-5
marinedgardo
Costa Rica
roy@mcscomputer Posted at 2015-5-6 07:52
When you bind your unit and put in the MAC address which mac address are you using. The one on the W ...
I use one that DJI support recode for me!, that is the same that was in the box
2015-5-5
