Scatterblak
fans0c2917d9 Posted at 2018-12-15 14:41
You're not getting the verification code because your firewall is blocking dji assistant. If you're using a mac go to your system preferences, security and private, firewall, click on firewall options. Then click on the plus sign and add the relevant dji assistant application(s). See photo below. Once added, restart the app and you would be good to go.
Hope this helps.
This is incorrect - you can safely ignore this post, if you're using DJI 2 Assistant to connect to a Phantom 4. |
