A CW
Flight distance : 13926112 ft
Do also note the following too: -
-The MPP is, without exception, the quietest drone DJI have ever made. You won't hear it at 400' AGL or 200' away from you - you will hear the Air. That will make it more noticeable to passers-by and attract more attention on you when flying.
-The MPP will give you an extra 9 minutes of flight time per battery. Two MPP batteries will therefore give you the same flight time as three MA batteries - so less to carry and better for longer time lapses and B-rolls. The size difference when folded is minimal too - my MPP fits perfectly in my 5L Peak Design sling with 3 batteries, RC, iPhone 7+ and a host of accessories and I hike for miles with it slung over my shoulder
-The MPP RC has a built in LCD screen so if the app crashes during flight you can still see vital information to help you control the drone and know if it is flying away from you... though the MPP also has dual compass - unlike the MA with just one
-The MPP uses Ocusync transmission technology - vastly superior to the WiFi on the MA. Not only to double the operating range over the MA but has less latency, less drop outs, less glitches, wireless use of goggles, live feed to your device in 1080p over 720p on the MA, dual RC controls in a master/slave set up
-The MPP has fixed wing mode, waypoints, course lock, home lock and still has active track, tap fly, tripod, terrain follow, POI, quick shots etc and reaches over 40MPH in Sport mode
-The camera on the MPP can record up to c.4K - not just UHD, has a wider iris for improved low light shooting, portrait mode, manual focus controls for shallow focus images, x2 digital zoom - both have the same sensor and megapixels for stills
-The MPP has a faster air speed in p-mode at up to 36MPH with OA turned off - you'll get from A-B quicker and cover more footage due to the increased flight distance you can cover off of one battery - 15KM with the MPP
-Get the DJI advanced charging hub and you will be able to charge your batteries semi-simultaniously - unlike the Air which is sequential
-The flymore combo on the MPP is equipped with a car charger - you'll have to buy that separately with the Air - when in stock.
-The MPP flymore combo is £510 more than the MA flymore combo though - but I guess there are many reasons for that... ;-)
The MA is an excellent drone but it is important that you are aware of what both truly offer then go with what suits your needs best. For me, I prefer my MPP to my P4Pro which has a camera that wipes the floor with any Mavic.
