Mavic Air FCC or CE mode
2625 4 2018-3-26
fans6e87d552
Is there anyway to verify that you are on CE or FCC other than checking the channel bandwidth? I have have heard that you can still be on ce even if the channels display 1-11 channels on the 2.4ghz band.
2018-3-26
Jos A
Flight distance : 73209 ft
yes on your phone check country code with a viewer.
dji-dji.go.v4-log-cache-areacode
open a log.txt with html viewer, there must be ac=US and near city=USthat's android i don't now on Iphone
2018-3-26
fans6e87d552
Is there a way you can do this on ios?
2018-3-26
DJI Thor
Flight distance : 13602 ft
You can tell me which area you wanna know, or you can check the specific area with our support. http://www.dji.com/support
2018-3-26
Robothamster
Flight distance : 51135 ft
If you go to the screen that allows you to select Wi-Fi channel, CE has 13 2.4GHz channels and FCC only has 11.
Edit - ignore, I've just read the OP properly haha.
2018-3-26
