ESC Status Error on Phantom 3 Pro after Firmware Update
12Next >
7216 63 2018-3-28
StevenHuff
Flight distance : 333852 ft
I've suddenly start receiving ESC status error after upgrading my P3 Pro to firmware P3X_FW_V01.11.0020.bin. Prior to the upgrade, everything was working perfectly. Will someone please help me. Thank you
2018-3-28
DJI Thor
Flight distance : 13602 ft
Steven, you can try to update the firmware we provided. See if it works.
2018-3-28
StevenHuff
DJI Thor Posted at 2018-3-28 17:51
Thank you!!!  This firmware update solved the problem.  I appreciate your help!!
2018-3-28
DJI Thor
StevenHuff Posted at 2018-3-28 20:24
Good to hear. Should you have any further questions, please feel free to contact us, we'd glad to help.
2018-3-30
apc
Cuba
having the same issue here could you share the .bin file?
2018-12-10
fansfe479993
Flight distance : 2436270 ft
I replaced my ESC and replaced one motor and also made sure that the software was up to date also I reinstalled the software a couple times and still have an esc error. I believe that one of the other motors could have a little dirt in it, would that cause an esc error?
2018-12-11
fans94a8fc8f
HI. I have a p3 professional and crashed it and damaged the camera. So I put an advanced camera on it   Brand new. And now I have the esc error. Can u help
2019-2-17
DJI Thor
fans94a8fc8f Posted at 2-17 13:23
Hi there, may I know if there is only the camera damaged after the crash? And what's the operation before the ECS error shows up? If the ESC error exists after you tried to update the firmware, I will PM you the firmware to try.
If the error shows up after changing the camera or the crash, you may try to update the original Phantom 3 Adv firmware for the drone first and see if this helps.
But as the drone crashed before, I may suggest that you send the drone in for diagnosis for the full performance.
2019-2-17
DJI Thor
wamuBugMe Posted at 4-24 03:44
Hey DJI Thor, I'm experiencing the same problem. Would you please send me the firmware you talk about?
Greets
Hi wamuBugMe, may I know the specific model of your drone? And can I know the operation before the case happened?
2019-4-24
djiuser_JZsGxvVfqSyl
Philippines
Hi dji thor,,i have experience the same problem an esc error status when ill upgrade the firmware to the v 1.11.20...can u please help me to fix my phantom 3 advanced.ty
2019-4-28
Neville
Flight distance : 675499 ft
I upgraded to v1.11.0020 and now I am also getting the ESC error.  Please advise how this can be fixed.
2019-4-29
Neville
Sorry, its a P3P
2019-4-29
turbospooky
Denmark
DJI Thor Posted at 2-17 18:41
Hi Thor
I have the same problem after update  my P3P to 020 firmware. Is there a newer a firmaware you can PM?
2019-5-6
DJI Thor
turbospooky Posted at 5-6 10:31
Hi Thor
Hi there, I had sent you PM, please kindly check.
2019-5-6
DJI Thor
Neville Posted at 4-29 02:25
Hi Neville, sorry for the late reply. I sent you PM about the link of the firmware, please kindly check.
2019-5-6
DJI Thor
djiuser_JZsGxvVfqSyl Posted at 4-28 15:05
Hi there, I am sorry for the delay, PM sent, please kindly check.
2019-5-6
djiuser_lqwuL5TA9dYd
Flight distance : 49150 ft
Argentina
I upgraded to 1.11 and now i have the same issue plz send me the file... I have a phantom 3 adv
2019-6-7
Dante.Pinkman
Argentina
DJI Thor Posted at 5-6 19:05
Hi Thor.
I recently upgraded to 1.11 drone and controller and now i have the same issue (ESC Error Message)  plz send me the file... I have a phantom 3 adv.
2019-6-8
fans478bee35
Flight distance : 72805 ft
Indonesia
Hello..
I have problem with my P3A..after update RC firmware to 1.9.2 version, and then after link RC...my P3A always give me notice everytime i use dji go app to update the firmware on aircraft.
Rc and aircraft can connected but I can't turn on the proper
My aircraft firmware version 1.6.40 ..the problem is..the version firmware on dji.com is lower than mine...firmware version is 1.11.20
Anyone can help me please??
2019-6-9
DJI Thor
Dante.Pinkman Posted at 6-8 21:47
Hi Thor.
Hi Dante, I am sorry for the late reply. I had sent you PM, please kindly check.
2019-6-10
DJI Thor
fans478bee35 Posted at 6-9 04:03
Hello..
Hi there, firmware v1.6.40 is an older firmware, the latest official firmware for Phantom 3 Adv is v1.11.20, please download the latest firmware v1.11.20 from https://www.dji.com/phantom-3-adv/info#downloads and update again.
2019-6-10
DJI Phantom3Pro
Flight distance : 109570 ft
I believe I have a firmware issue.  The only indication I have is no image transmission from the camera.  The AC seems to function normally otherwise.  I downloaded the current firmware and with the controller turned off, attempted to "upgrade" the firmware.  I captured the firmware log file on my MAC and is pasted below.  Any suggestions would be most appreciated!
[00012240][01 00] Firmware upgrade finished successfully.
[00012388]Done.
[00012479]Packet [C:\P3X_FW_V01.11.0020.bin] resumed, card sn [0x43428892].
[00012611]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012737]Version checking[2]...
[00013020][03 06][00] v2.1.6.18 -> v2.4.20.50 need upgrade.
[00013181][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00013329][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00013539][11 00][00] v1.6.1.0 -> v1.8.0.0 need upgrade.
[00013761][11 01][00] v1.6.1.0 -> v2.0.0.33, firmware v1.6.1.0 not support.
[00013879][11 01][00] v1.6.1.0 -> v2.0.0.33
[00014013][12 00][00] v1.8.0.0 -> v1.12.0.0 need upgrade.
[00014113][12 01][00] v1.8.0.0 -> v1.12.0.0 need upgrade.
[00014273][12 02][00] v1.8.0.0 -> v1.12.0.0 need upgrade.
[00014533][12 03][00] v1.8.0.0 -> v1.12.0.0 need upgrade.
[00014770][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014944][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00015173][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00015339][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015432][01 00][05] v1.32.5432 -> v1.32.5432
[00015485][01 01][00] v1.6.2736 -> v1.32.5432 need upgrade
[00015520][08 00][00] v0.11.0.4 -> v0.13.0.7 need upgrade.
[00015559][09 00][00] v1.7.0.3 -> v4.1.0.0 need upgrade.
[00015586]Done.
[00015617]Firmware upgrading[2]...
[00015749][01 01] Firmware upgrade start...
[00046006][01 01] Firmware upgrade finished successfully.
[00046856][08 00] Firmware upgrade start...
[00012479]========== remo-con disconnect. boot(15) ============
[00012509]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012538]Packet upgrade start...
[00012577]Packet checking...
[00012608]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012670]Done.
[00012697]Version checking[1]...
[00012764][03 06][00] v2.1.6.18 -> v2.4.20.50 need upgrade.
[00012828][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012863][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00012964][11 00][00] v1.6.1.0 -> v1.8.0.0 need upgrade.
[00013164][11 01][00] v1.6.1.0 -> v2.0.0.33, firmware v1.6.1.0 not support.
[00013192][11 01][00] v1.6.1.0 -> v2.0.0.33
[00013298][12 00][00] v1.8.0.0 -> v1.12.0.0 need upgrade.
[00013378][12 01][00] v1.8.0.0 -> v1.12.0.0 need upgrade.
[00013452][12 02][00] v1.8.0.0 -> v1.12.0.0 need upgrade.
[00013517][12 03][00] v1.8.0.0 -> v1.12.0.0 need upgrade.
[00026046][15 00][00] device not detected.
[00026138][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00026254][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00026313][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026354][01 00][00] v1.32.5432 -> v1.32.5432
[00026384][01 01][00] v1.32.5432 -> v1.32.5432
[00038912][08 00][00] device not detected.
[00038973][09 00][00] v1.7.0.3 -> v4.1.0.0 need upgrade.
[00039004]Done.
[00041036]Waiting for user confirm...
[00051066]Timeout, start upgrade automatically.
[00051133]Firmware upgrading[1]...
[00051181][12 00] Firmware upgrade start...
[00114198][12 00] Firmware upgrade finished successfully.
[00114244][12 01] Firmware upgrade start...
[00180002][12 01] Firmware upgrade finished successfully.
[00180047][12 02] Firmware upgrade start...
[00244267][12 02] Firmware upgrade finished successfully.
[00244315][12 03] Firmware upgrade start...
[00012420]========== remo-con disconnect. boot(15) ============
[00012448]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012479]Packet upgrade start...
[00012515]Packet checking...
[00012548]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012615]Done.
[00012647]Version checking[1]...
[00012719][03 06][00] v2.1.6.18 -> v2.4.20.50 need upgrade.
[00012779][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012815][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00012935][11 00][00] v1.6.1.0 -> v1.8.0.0 need upgrade.
[00013036][11 01][00] v1.6.1.0 -> v2.0.0.33, firmware v1.6.1.0 not support.
[00013066][11 01][00] v1.6.1.0 -> v2.0.0.33
[00013149][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013229][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013384][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013464][12 03][00] v1.12.0.0 -> v1.12.0.0
[00025996][15 00][00] device not detected.
[00026090][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00026209][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00026286][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026315][01 00][00] v1.32.5432 -> v1.32.5432
[00026348][01 01][00] v1.32.5432 -> v1.32.5432
[00038877][08 00][00] device not detected.
[00038924][09 00][00] v1.7.0.3 -> v4.1.0.0 need upgrade.
[00038959]Done.
[00040988]Waiting for user confirm...
[00051021]Timeout, start upgrade automatically.
[00051084]Firmware upgrading[1]...
[00051144][17 00] Firmware upgrade start...
[00145086][17 00] Firmware upgrade finished successfully.
[00145125][17 01] Firmware upgrade start...
[00012427]========== remo-con disconnect. boot(15) ============
[00012459]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012490]Packet upgrade start...
[00012527]Packet checking...
[00012560]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012629]Done.
[00012660]Version checking[1]...
[00012718][03 06][00] v2.1.6.18 -> v2.4.20.50 need upgrade.
[00012783][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012819][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00012922][11 00][00] v1.6.1.0 -> v1.8.0.0 need upgrade.
[00013018][11 01][00] v1.6.1.0 -> v2.0.0.33, firmware v1.6.1.0 not support.
[00013047][11 01][00] v1.6.1.0 -> v2.0.0.33
[00013118][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013197][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013296][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013397][12 03][00] v1.12.0.0 -> v1.12.0.0
[00025934][15 00][00] device not detected.
[00026012][17 00][00] v0.0.0.0 -> v1.1.1.7 need upgrade.
[00026112][17 01][00] v0.0.0.0 -> v1.0.2.7 need upgrade.
[00026172][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026204][01 00][00] v1.32.5432 -> v1.32.5432
[00026239][01 01][00] v1.32.5432 -> v1.32.5432
[00038780][08 00][00] device not detected.
[00038913][09 00][00] v1.7.0.3 -> v4.1.0.0 need upgrade.
[00038951]Done.
[00040983]Waiting for user confirm...
[00051014]Timeout, start upgrade automatically.
[00051079]Firmware upgrading[1]...
[00051141][17 00] Firmware upgrade start...
[00131647][17 00] Firmware upgrade finished successfully.
[00131690][17 01] Firmware upgrade start...
[00193130][17 01] Firmware upgrade finished successfully.
[00193172][11 00] Firmware upgrade start...
[00243065][11 00] Firmware upgrade finished successfully.
[00243113][03 05] Firmware upgrade start...
[00320682][03 05] Firmware upgrade finished successfully.
[00320929][03 06] Firmware upgrade start...
[00012910]========== remo-con disconnect. boot(15) ============
[00013034]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00013153]Packet upgrade start...
[00013282]Packet checking...
[00013411]Packet vlink 01.11.0020 <-> 01.11.0020.
[00013560]Done.
[00013659]Version checking[1]...
[00013751][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[00013911][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014047][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00088529]========== remo-con disconnect. boot(15) ============
[00088561]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00088598]Packet upgrade start...
[00088631]Packet checking...
[00088663]Packet vlink 01.11.0020 <-> 01.11.0020.
[00088725]Done.
[00088762]Version checking[1]...
[00088814][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[00088874][03 05][00] v34.2.0.9 -> v34.2.0.9
[00088913][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00101453][11 00][00] device not detected.
[00113984][11 01][00] device not detected.
[00126523][12 00][00] device not detected.
[00139051][12 01][00] device not detected.
[00151580][12 02][00] device not detected.
[00164107][12 03][00] device not detected.
[00164234][15 00][00] v1.1.2.0 -> v1.1.2.0
[00176764][17 00][00] device not detected.
[00189293][17 01][00] device not detected.
[00189430][19 00][00] v1.0.8.96 -> v1.0.8.96
[00189460][01 00][00] v1.32.5432 -> v1.32.5432
[00189490][01 01][00] v1.32.5432 -> v1.32.5432
[00189546][08 00][00] v0.11.0.4 -> v0.13.0.7 need upgrade.
[00189590][09 00][00] v1.7.0.3 -> v4.1.0.0 need upgrade.
[00189621]Done.
[00191649]Waiting for user confirm...
[00201677]Timeout, start upgrade automatically.
[00201740]Firmware upgrading[1]...
[00201770][08 00] Firmware checksum failed.
[00201800]Packet upgrade failed at firmware upgrade.
[00056585]========== remo-con disconnect. boot(15) ============
[00056616]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00056655]Packet upgrade start...
[00056691]Packet checking...
[00056725]Packet vlink 01.11.0020 <-> 01.11.0020.
[00056790]Done.
[00056830]Version checking[1]...
[00056898][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[00056958][03 05][00] v34.2.0.9 -> v34.2.0.9
[00057003][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00069541][11 00][00] device not detected.
[00082071][11 01][00] device not detected.
[00012509]========== remo-con disconnect. boot(15) ============
[00012543]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012576]Packet upgrade start...
[00012619]Packet checking...
[00012656]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012719]Done.
[00012759]Version checking[1]...
[00012814][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[00012894][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012941][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00025474][11 00][00] device not detected.
[00038011][11 01][00] device not detected.
[00012481]========== remo-con disconnect. boot(15) ============
[00012515]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012548]Packet upgrade start...
[00012587]Packet checking...
[00012622]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012687]Done.
[00012720]Version checking[1]...
[00012786][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[00012921][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012962][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00012480]========== remo-con disconnect. boot(15) ============
[00012512]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012545]Packet upgrade start...
[00012581]Packet checking...
[00012620]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012686]Done.
[00012787][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[00012866][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012904][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00012820]========== remo-con disconnect. boot(15) ============
[00012855]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012889]Packet upgrade start...
[00012931]Packet checking...
[00012966]Packet vlink 01.11.0020 <-> 01.11.0020.
[00013031]Done.
[00013065]Version checking[1]...
[00013126][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[00013186][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013228][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00025763][11 00][00] device not detected.
[00038297][11 01][00] device not detected.
[00050838][12 00][00] device not detected.
[00063369][12 01][00] device not detected.
[00075906][12 02][00] device not detected.
[00088442][12 03][00] device not detected.
[00100973][15 00][00] device not detected.
[00113506][17 00][00] device not detected.
[00126044][17 01][00] device not detected.
[00126102][19 00][00] v1.0.8.96 -> v1.0.8.96
[00126152][01 00][00] v1.32.5432 -> v1.32.5432
[00126192][01 01][00] v1.32.5432 -> v1.32.5432
[00138728][08 00][00] device not detected.
[00138783][09 00][00] v1.7.0.3 -> v4.1.0.0 need upgrade.
[00138823]Done.
[00140856]Waiting for user confirm...
[00150890]Timeout, start upgrade automatically.
[00150955]Firmware upgrading[1]...
[00151201][03 06] Firmware upgrade start...
[00530875][03 06] Firmware upgrade finished successfully.
[00531031][09 00] Firmware upgrade start...
[00583223][09 00] Firmware upgrade finished successfully.
[00583282][04 00] Firmware upgrade start...
[00012434]========== remo-con disconnect. boot(15) ============
[00012469]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012503]Packet upgrade start...
[00012544]Packet checking...
[00012577]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012647]Done.
[00012683]Version checking[1]...
[00012773][03 06][00] v2.4.20.50 -> v2.4.20.50
[00012853][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012899][04 00][00] v0.0.0.0 -> v1.48.0.0 need upgrade.
[00013033][11 00][00] v1.6.1.0 -> v1.8.0.0 need upgrade.
[00013153][11 01][00] v1.6.1.0 -> v2.0.0.33, firmware v1.6.1.0 not support.
[00013188][11 01][00] v1.6.1.0 -> v2.0.0.33
[00013293][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013384][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013484][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013589][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026127][15 00][00] device not detected.
[00026222][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026343][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026390][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026426][01 00][00] v1.32.5432 -> v1.32.5432
[00026464][01 01][00] v1.32.5432 -> v1.32.5432
[00038999][08 00][00] device not detected.
[00039070][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039103]Done.
[00041145]Waiting for user confirm...
[00051179]Timeout, start upgrade automatically.
[00051251]Firmware upgrading[1]...
[00051301][11 00] Firmware upgrade start...
[00098252][11 00] Firmware upgrade finished successfully.
[00098313][04 00] Firmware upgrade start...
[00012504]Packet upgrade start...
[00012545]Packet checking...
[00012586]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012653]Done.
[00012687]Version checking[1]...
[00012758][03 06][00] v2.4.20.50 -> v2.4.20.50
[00012823][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012946][04 00][00] v0.0.0.0 -> v1.48.0.0 need upgrade.
[00013058][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013180][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013214][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013313][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013392][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013492][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013572][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026113][15 00][00] device not detected.
[00026208][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026353][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026403][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026445][01 00][00] v1.32.5432 -> v1.32.5432
[00026481][01 01][00] v1.32.5432 -> v1.32.5432
[00039017][08 00][00] device not detected.
[00039084][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039123]Done.
[00041158]Waiting for user confirm...
[00051193]Timeout, start upgrade automatically.
[00051265]Firmware upgrading[1]...
[00051330][04 00] Firmware upgrade start...
[00100556][04 00] Firmware upgrade finished successfully.
[00100594]Done.
[00100630]Version checking[2]...
[00100713][03 06][00] v2.4.20.50 -> v2.4.20.50
[00100783][03 05][00] v34.2.0.9 -> v34.2.0.9
[00100843][04 00][05] v1.48.0.0 -> v1.48.0.0
[00100944][11 00][00] v1.8.0.0 -> v1.8.0.0
[00101064][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00101102][11 01][00] v1.8.0.0 -> v2.0.0.33
[00101198][12 00][00] v1.12.0.0 -> v1.12.0.0
[00101324][12 01][00] v1.12.0.0 -> v1.12.0.0
[00101425][12 02][00] v1.12.0.0 -> v1.12.0.0
[00101513][12 03][00] v1.12.0.0 -> v1.12.0.0
[00114048][15 00][00] device not detected.
[00114133][17 00][00] v1.1.1.7 -> v1.1.1.7
[00114259][17 01][00] v1.0.2.7 -> v1.0.2.7
[00114308][19 00][00] v1.0.8.96 -> v1.0.8.96
[00114344][01 00][00] v1.32.5432 -> v1.32.5432
[00114388][01 01][00] v1.32.5432 -> v1.32.5432
[00126928][08 00][00] device not detected.
[00126990][09 00][00] v4.1.0.0 -> v4.1.0.0
[00127035]Packet upgrade failed at version checking.
[00012448]========== remo-con disconnect. boot(15) ============
[00012485]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012519]Packet upgrade start...
[00012558]Packet checking...
[00012601]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012669]Done.
[00012708]Version checking[1]...
[00012794][03 06][00] v2.4.20.50 -> v2.4.20.50
[00012899][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012950][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013077][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013194][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013234][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013327][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013434][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013533][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013648][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026187][15 00][00] device not detected.
[00026303][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026443][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026510][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026553][01 00][00] v1.32.5432 -> v1.32.5432
[00026595][01 01][00] v1.32.5432 -> v1.32.5432
[00039134][08 00][00] device not detected.
[00039189][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039229]Packet upgrade failed at version checking.
[00014685]========== remo-con disconnect. boot(15) ============
[00014726]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xc30510a5].
[00014770]Packet upgrade start...
[00014810]Packet checking...
[00014852]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014924]Done.
[00014970]Version checking[1]...
[00015053][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015132][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015178][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015332][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015452][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015491][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015580][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015680][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015780][12 02][00] v1.12.0.0 -> v1.12.0.0
[00015965][12 03][00] v1.12.0.0 -> v1.12.0.0
[00028507][15 00][00] device not detected.
[00028601][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028746][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028807][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028849][01 00][00] v1.32.5432 -> v1.32.5432
[00028889][01 01][00] v1.32.5432 -> v1.32.5432
[00041430][08 00][00] device not detected.
[00041487][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041527]Packet upgrade failed at version checking.
[00012584]========== remo-con disconnect. boot(15) ============
[00012640]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0xc30510a5].
[00012691]Packet upgrade start...
[00012736]Packet checking...
[00012778]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012848]Done.
[00012890]Version checking[1]...
[00012970][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013050][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013101][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013231][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013370][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013409][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013525][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013629][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013729][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013818][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026360][15 00][00] device not detected.
[00026455][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026579][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026647][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026687][01 00][00] v1.32.5432 -> v1.32.5432
[00026727][01 01][00] v1.32.5432 -> v1.32.5432
[00039268][08 00][00] device not detected.
[00039350][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039390]Packet upgrade failed at version checking.
[00014561]========== remo-con disconnect. boot(15) ============
[00014604]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00014641]Packet upgrade start...
[00014684]Packet checking...
[00014722]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014797]Done.
[00014836]Version checking[1]...
[00015014][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015114][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015161][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015294][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015415][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015462][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015563][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015663][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015764][12 02][00] v1.12.0.0 -> v1.12.0.0
[00015863][12 03][00] v1.12.0.0 -> v1.12.0.0
[00028402][15 00][00] device not detected.
[00028523][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028663][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028728][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028767][01 00][00] v1.32.5432 -> v1.32.5432
[00028810][01 01][00] v1.32.5432 -> v1.32.5432
[00041351][08 00][00] device not detected.
[00041410][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041457]Packet upgrade failed at version checking.
[00013264]========== remo-con disconnect. boot(15) ============
[00013301]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00013345]Packet upgrade start...
[00013396]Packet checking...
[00013454]Packet vlink 01.11.0020 <-> 01.11.0020.
[00013526]Done.
[00013565]Version checking[1]...
[00013624][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013684][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013746][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013868][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013984][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00014031][11 01][00] v1.8.0.0 -> v2.0.0.33
[00014121][12 00][00] v1.12.0.0 -> v1.12.0.0
[00014193][12 01][00] v1.12.0.0 -> v1.12.0.0
[00014273][12 02][00] v1.12.0.0 -> v1.12.0.0
[00014369][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026908][15 00][00] device not detected.
[00026993][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027114][17 01][00] v1.0.2.7 -> v1.0.2.7
[00027174][19 00][00] v1.0.8.96 -> v1.0.8.96
[00027219][01 00][00] v1.32.5432 -> v1.32.5432
[00027259][01 01][00] v1.32.5432 -> v1.32.5432
[00039810][08 00][00] device not detected.
[00039975][09 00][00] v4.1.0.0 -> v4.1.0.0
[00040015]Packet upgrade failed at version checking.
[00015221]========== remo-con disconnect. boot(15) ============
[00015259]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00015304]Packet upgrade start...
[00015349]Packet checking...
[00015390]Packet vlink 01.11.0020 <-> 01.11.0020.
[00015468]Done.
[00015510]Version checking[1]...
[00015602][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015678][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015724][04 00][00] v1.48.0.0 -> v1.48.0.0
[00018346][11 00][00] v1.8.0.0 -> v1.8.0.0
[00018462][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00018502][11 01][00] v1.8.0.0 -> v2.0.0.33
[00018618][12 00][00] v1.12.0.0 -> v1.12.0.0
[00018722][12 01][00] v1.12.0.0 -> v1.12.0.0
[00018823][12 02][00] v1.12.0.0 -> v1.12.0.0
[00018913][12 03][00] v1.12.0.0 -> v1.12.0.0
[00031463][15 00][00] device not detected.
[00031547][17 00][00] v1.1.1.7 -> v1.1.1.7
[00031666][17 01][00] v1.0.2.7 -> v1.0.2.7
[00031722][19 00][00] v1.0.8.96 -> v1.0.8.96
[00031767][01 00][00] v1.32.5432 -> v1.32.5432
[00031812][01 01][00] v1.32.5432 -> v1.32.5432
[00044354][08 00][00] device not detected.
[00044423][09 00][00] v4.1.0.0 -> v4.1.0.0
[00044464]Packet upgrade failed at version checking.
[00014801]========== remo-con disconnect. boot(15) ============
[00014846]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00014890]Packet upgrade start...
[00014942]Packet checking...
[00014989]Packet vlink 01.11.0020 <-> 01.11.0020.
[00015066]Done.
[00015109]Version checking[1]...
[00015188][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015268][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015322][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015449][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015567][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015611][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015732][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015897][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015997][12 02][00] v1.12.0.0 -> v1.12.0.0
[00016101][12 03][00] v1.12.0.0 -> v1.12.0.0
[00028650][15 00][00] device not detected.
[00028736][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028857][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028913][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028958][01 00][00] v1.32.5432 -> v1.32.5432
[00029010][01 01][00] v1.32.5432 -> v1.32.5432
[00041556][08 00][00] device not detected.
[00041613][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041667]Packet upgrade failed at version checking.
[00012487]========== remo-con disconnect. boot(15) ============
[00012528]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012570]Packet upgrade start...
[00012620]Packet checking...
[00012664]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012736]Done.
[00012783]Version checking[1]...
[00012876][03 06][00] v2.4.20.50 -> v2.4.20.50
[00012956][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013002][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013137][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013256][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013296][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013401][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013504][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013609][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013745][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026294][15 00][00] device not detected.
[00026385][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026528][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026580][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026632][01 00][00] v1.32.5432 -> v1.32.5432
[00026673][01 01][00] v1.32.5432 -> v1.32.5432
[00039214][08 00][00] device not detected.
[00039301][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039341]Packet upgrade failed at version checking.
[00012593]========== remo-con disconnect. boot(15) ============
[00012635]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012676]Packet upgrade start...
[00012729]Packet checking...
[00012864]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012937]Done.
[00012980]Version checking[1]...
[00013080][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013158][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013213][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013338][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013476][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013638][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013740][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013838][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013947][12 02][00] v1.12.0.0 -> v1.12.0.0
[00014047][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026590][15 00][00] device not detected.
[00026686][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026820][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026897][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026941][01 00][00] v1.32.5432 -> v1.32.5432
[00026985][01 01][00] v1.32.5432 -> v1.32.5432
[00039544][08 00][00] device not detected.
[00039617][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039657]Packet upgrade failed at version checking.
[00278516]========== remo-con disconnect. boot(15) ============
[00278556]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00278598]Packet upgrade start...
[00278647]Packet checking...
[00278696]Packet vlink 01.11.0020 <-> 01.11.0020.
[00278771]Done.
[00278812]Version checking[1]...
[00278918][03 06][00] v2.4.20.50 -> v2.4.20.50
[00278998][03 05][00] v34.2.0.9 -> v34.2.0.9
[00279064][04 00][00] v1.48.0.0 -> v1.48.0.0
[00279181][11 00][00] v1.8.0.0 -> v1.8.0.0
[00279326][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00279375][11 01][00] v1.8.0.0 -> v2.0.0.33
[00279492][12 00][00] v1.12.0.0 -> v1.12.0.0
[00279592][12 01][00] v1.12.0.0 -> v1.12.0.0
[00279691][12 02][00] v1.12.0.0 -> v1.12.0.0
[00279791][12 03][00] v1.12.0.0 -> v1.12.0.0
[00292335][15 00][00] device not detected.
[00292432][17 00][00] v1.1.1.7 -> v1.1.1.7
[00292572][17 01][00] v1.0.2.7 -> v1.0.2.7
[00292639][19 00][00] v1.0.8.96 -> v1.0.8.96
[00292762][01 00][00] v1.32.5432 -> v1.32.5432
[00292805][01 01][00] v1.32.5432 -> v1.32.5432
[00305350][08 00][00] device not detected.
[00305420][09 00][00] v4.1.0.0 -> v4.1.0.0
[00305463]Packet upgrade failed at version checking.
[00816717]========== remo-con disconnect. boot(15) ============
[00816766]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00816809]Packet upgrade start...
[00816863]Packet checking...
[00816906]Packet vlink 01.11.0020 <-> 01.11.0020.
[00816979]Done.
[00817030]Version checking[1]...
[00817111][03 06][00] v2.4.20.50 -> v2.4.20.50
[00817196][03 05][00] v34.2.0.9 -> v34.2.0.9
[00817246][04 00][00] v1.48.0.0 -> v1.48.0.0
[00817358][11 00][00] v1.8.0.0 -> v1.8.0.0
[00817476][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00817526][11 01][00] v1.8.0.0 -> v2.0.0.33
[00817600][12 00][00] v1.12.0.0 -> v1.12.0.0
[00817691][12 01][00] v1.12.0.0 -> v1.12.0.0
[00817779][12 02][00] v1.12.0.0 -> v1.12.0.0
[00817875][12 03][00] v1.12.0.0 -> v1.12.0.0
[00830418][15 00][00] device not detected.
[00830520][17 00][00] v1.1.1.7 -> v1.1.1.7
[00830645][17 01][00] v1.0.2.7 -> v1.0.2.7
[00830706][19 00][00] v1.0.8.96 -> v1.0.8.96
[00830754][01 00][00] v1.32.5432 -> v1.32.5432
[00830798][01 01][00] v1.32.5432 -> v1.32.5432
[00843361][08 00][00] device not detected.
[00843426][09 00][00] v4.1.0.0 -> v4.1.0.0
[00843468]Packet upgrade failed at version checking.
[00117329]========== remo-con disconnect. boot(15) ============
[00117375]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00117424]Packet upgrade start...
[00117481]Packet checking...
[00117529]Packet vlink 01.11.0020 <-> 01.11.0020.
[00117604]Done.
[00117659]Version checking[1]...
[00117741][03 06][00] v2.4.20.50 -> v2.4.20.50
[00117840][03 05][00] v34.2.0.9 -> v34.2.0.9
[00117895][04 00][00] v1.48.0.0 -> v1.48.0.0
[00118022][11 00][00] v1.8.0.0 -> v1.8.0.0
[00118140][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00118275][11 01][00] v1.8.0.0 -> v2.0.0.33
[00118393][12 00][00] v1.12.0.0 -> v1.12.0.0
[00118493][12 01][00] v1.12.0.0 -> v1.12.0.0
[00118593][12 02][00] v1.12.0.0 -> v1.12.0.0
[00118693][12 03][00] v1.12.0.0 -> v1.12.0.0
[00131242][15 00][00] device not detected.
[00131330][17 00][00] v1.1.1.7 -> v1.1.1.7
[00131475][17 01][00] v1.0.2.7 -> v1.0.2.7
[00131545][19 00][00] v1.0.8.96 -> v1.0.8.96
[00131591][01 00][00] v1.32.5432 -> v1.32.5432
[00131649][01 01][00] v1.32.5432 -> v1.32.5432
[00144197][08 00][00] device not detected.
[00144267][09 00][00] v4.1.0.0 -> v4.1.0.0
[00144322]Packet upgrade failed at version checking.
[00014658]========== remo-con disconnect. boot(15) ============
[00014706]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00014753]Packet upgrade start...
[00014798]Packet checking...
[00014844]Packet vlink 01.11.0020 <-> 01.11.0020.
[00014925]Done.
[00014968]Version checking[1]...
[00015052][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015131][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015181][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015293][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015433][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015477][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015592][12 00][00] v1.12.0.0 -> v1.12.0.0
[00015683][12 01][00] v1.12.0.0 -> v1.12.0.0
[00015782][12 02][00] v1.12.0.0 -> v1.12.0.0
[00028404][15 00][00] device not detected.
[00028503][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028643][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028704][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028750][01 00][00] v1.32.5432 -> v1.32.5432
[00028794][01 01][00] v1.32.5432 -> v1.32.5432
[00041340][08 00][00] device not detected.
[00041403][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041450]Packet upgrade failed at version checking.
[00012531]========== remo-con disconnect. boot(15) ============
[00012576]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012704]Packet upgrade start...
[00012794]Packet checking...
[00012842]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012922]Done.
[00012966]Version checking[1]...
[00013031][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013113][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013165][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013272][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013552][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013600][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013701][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013792][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013881][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013981][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026531][15 00][00] device not detected.
[00026622][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026736][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026801][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026848][01 00][00] v1.32.5432 -> v1.32.5432
[00026894][01 01][00] v1.32.5432 -> v1.32.5432
[00039448][08 00][00] device not detected.
[00039522][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039567]Packet upgrade failed at version checking.
[00012591]========== remo-con disconnect. boot(15) ============
[00012640]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x43428892].
[00012684]Packet upgrade start...
[00012732]Packet checking...
[00012783]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012860]Done.
[00012911]Version checking[1]...
[00013000][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013100][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013153][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013280][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013399][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013451][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013545][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013648][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013749][12 02][00] v1.12.0.0 -> v1.12.0.0
[00013849][12 03][00] v1.12.0.0 -> v1.12.0.0
[00026391][15 00][00] device not detected.
[00026510][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026747][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026821][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026866][01 00][00] v1.32.5432 -> v1.32.5432
[00026912][01 01][00] v1.32.5432 -> v1.32.5432
[00039465][08 00][00] device not detected.
[00039536][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039581]Packet upgrade failed at version checking.
[00012624]Packet upgrade start...
[00012675]Packet checking...
[00012726]Packet vlink 01.11.0020 <-> 01.11.0020.
[00012799]Done.
[00012851]Version checking[1]...
[00012932][03 06][00] v2.4.20.50 -> v2.4.20.50
[00013015][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013069][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013191][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013316][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013369][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013464][12 00][00] v1.12.0.0 -> v1.12.0.0
[00013564][12 01][00] v1.12.0.0 -> v1.12.0.0
[00013640][12 02][00] v1.12.0.0 -> v1.12.0.0
[00026293][15 00][00] device not detected.
[00026402][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026525][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026627][01 00][00] v1.32.5432 -> v1.32.5432
[00026678][01 01][00] v1.32.5432 -> v1.32.5432
[00039226][08 00][00] device not detected.
[00039300][09 00][00] v4.1.0.0 -> v4.1.0.0
[00039355]Packet upgrade failed at version checking.
[00014882]========== remo-con disconnect. boot(15) ============
[00014932]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x280133c2].
[00014983]Packet upgrade start...
[00015036]Packet checking...
[00015081]Packet vlink 01.11.0020 <-> 01.11.0020.
[00015167]Done.
[00015213]Version checking[1]...
[00015301][03 06][00] v2.4.20.50 -> v2.4.20.50
[00015381][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015450][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015663][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015781][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015838][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015935][12 00][00] v1.12.0.0 -> v1.12.0.0
[00016040][12 01][00] v1.12.0.0 -> v1.12.0.0
[00016124][12 02][00] v1.12.0.0 -> v1.12.0.0
[00016227][12 03][00] v1.12.0.0 -> v1.12.0.0
[00028776][15 00][00] device not detected.
[00028885][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029015][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029087][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029135][01 00][00] v1.32.5432 -> v1.32.5432
[00029189][01 01][00] v1.32.5432 -> v1.32.5432
[00041739][08 00][00] device not detected.
[00041806][09 00][00] v4.1.0.0 -> v4.1.0.0
[00041863]Packet upgrade failed at version checking.
2019-6-10
KenDuke
Flight distance : 50837 ft
Sorry to hear about your crash.  However, the camera  you put on is just a 2.7K camera, and not the 4K camera the Pro comes with.
The ESC error is a software related issue, that DJI will not release to the general public.  You have to ask for it.
DJI Susan and Thor are handing out the BIN file that fixes this issue on most peoples Phantom 3.
2019-6-12
Dante.Pinkman
Argentina
DJI Thor Posted at 6-10 01:14
The upgrade works perfect, thanks
2019-6-22
DJI Thor
Dante.Pinkman Posted at 6-22 02:40
It's great to know the result, thank you for getting back. Happy flying!
2019-6-23
DJI Thor
DJI Phantom3Pro Posted at 6-10 16:46
I am sorry for the late reply. For the issue, please provide a screenshot of the DJI GO app and the firmware info (General Settings > About) when connecting the drone and controller for further checking. Thank you.
2019-6-23
wolfie212
Flight distance : 107018 ft
been having same esc error after upgrading. Susan sent me the bin it tried to updte but shows failed. but the app is now showing 1.11.20+ and drone still will not start. any other ideas.
2019-6-28
djiuser_JI0H3nD4VPsu
Flight distance : 20167 ft
Vietnam
gmail : ngaithien23@gmail.com
2019-6-28
DJI Susan
djiuser_JI0H3nD4VPsu Posted at 6-28 19:11
gmail :
I've received your message in PM and responded as well, please kindly check later, thanks!
2019-7-4
DJI Susan
wolfie212 Posted at 6-28 14:03
Sorry for the late response. If the issue remains after updating to V1.11.30, please kindly start a case and send the unit in for diagnosis: https://www.dji.com/support
BTW, if you need one's attention, please kindly click the reply button under one's message, so that he/she can get the reminder and handle it timely, thanks!
2019-7-4
djiuser_usMNhFoE7Apx
Flight distance : 209760 ft
Having same ESC Status Error on Phantom 3 Pro.
No crashes. Latest firmware installed.
Can you send me the .bin file that you have sent others that had this same problem?
2019-7-6
Why does it take days to have someone send me a simple link?
2019-7-9
DJI Susan Posted at 7-4 00:48
Can I please get a link to the v 1.11.30 bin file please?
2019-7-9
DJI Susan
djiuser_usMNhFoE7Apx Posted at 7-9 21:20
Sorry for the late response. I've sent you a message in PM, please kindly check later, thanks!
2019-7-11
fans67f7a24c
Hello, coming into this thread late but I just updated the firmware on my P3P after not flying it for a couple years and now I am getting ESC status error everything. Please help
2020-5-4
samMK
Flight distance : 3599 ft
Hello, i'm having problem with my Phantom 3 pro.Recently i update now it is giving me ESC status error. Anyone can help Please
2020-8-25
Lindosvaldo
Flight distance : 620748 ft
Brazil
OI, Bom dia;
possuo o P3/ADV
serial number: P76UDL0282005F
e tenho tido o seguinte mensagem de erro: ESC STATUS ERROR
os motores não ligam
o drone não sofreu queda
ele foi guardado voando normalmente e quando fui usar apareceu este erro
me ajude por favor?
2020-9-9
franklinrocha2010gmail.com
Flight distance : 80928 ft
Brazil
Estou com um phantom 3advanced  com erro de esc disseram que tinha que trocar a placa ai comprei uma e deu o mesmo erro o drone está com a última atualização quem pode me ajudar
2020-9-15
Brazil
I have a 3advanced phantom with an esc error they said I had to change the card there I bought one and it gave the same error the drone has the latest update who can help me
2020-9-15
Brazil
DJI Susan Posted at 2019-7-4 00:48
Preciso da atualização 1130 estou com o mesmo problema de erro de esc no meu phantom 3advanced meu email é franklinrocha2010@gmail.com
2020-9-16
12Next >
