Mavic air and new iPhone 8 compatability
1324 5 2018-3-31
Jon Connelly
I just tried out the new iPhone 8 with my Mavic Air and all goes well until you try and take off for a flight. The application says "unable to take off" and when you click on the warning I got a message saying to check the aircraft battery which might not be securely attached.  The battery is fine, no issue with how it is installed and when you click on the battery status it checks out OK.  Anyone run into this yet?
2018-3-31
Jeff7577
Flight distance : 1916821 ft
It does that when one of the battery latches isn’t engaged fully.
2018-3-31
Jon Connelly
Jeff7577 Posted at 2018-3-31 14:58
I have 3 batteries and each of them causes the same issue, if I take and use my old iPhone 6 in place of the iPhone 8 it works just fine
2018-3-31
AdZaM
I have a iPhone 8, Not had any issues. Latest Firmware or Previous Firmware.
2018-3-31
Mavic Ace
Flight distance : 333976 ft
Are you trying to control it with the phone?
2018-3-31
DJI Thor
Flight distance : 13602 ft
Jon Connelly Posted at 2018-3-31 15:08
Jon, just to assure again, the error doesn't pop up when using iPhone 6 but exists in the iPhone 8, you are sure that the batteries are all mounted correctly, right?
Could you please provide me with the app version, the screenshots of this case and the flight logs of each case, the picture of the battery when connecting the iPhone 8? I would like to have our engineers to check.
2018-4-1
