Power on problem
860 10 2018-4-8
MPA
After a few flights I started having compass calibration issues. Aircraft would not fly. After many attempts at calibration I finally replaced compass. Compass problem solved however aircraft will not take off. Props shudder. I turned aircraft off and now I cannot get aircraft to power up. Battery shuts down after few seconds. Any ideas?
2018-4-8
RedHotPoker
Flight distance : 165105 ft
Do you have another battery?
Not sure what else to suggest.
Check the battery contacts, in the aircraft as well.
RedHotPoker
2018-4-8
Peterx
Flight distance : 1499708 ft
Fire battery on out side the AC and look what is the reaction of the LEDs and then switch it off and do it again inside the AC. You may have a look on to the contacts as RedHotPoker mentioned.
2018-4-8
DJI Susan
Hi there, it is recommended changing to another working battery to see whether the drone can be powered on or not. If yes, please check whether there is any error message in APP to guide the further steps.
2018-4-9
MPA
I have three batteries none will power up aircraft. Battery contacts look fine.
2018-4-9
ALABAMA
Flight distance : 10442687 ft
Did you check the board for damage while installing the new compass?
2018-4-9
MPA
I inspected not sure what to look for
2018-4-9
MPA
MPA Posted at 2018-4-9 05:36
Sending to DJI for repair
2018-4-9
DJI Susan
MPA Posted at 2018-4-9 19:12
Sorry about this. Please kindly start a case and send it in from here: https://www.dji.com/support
2018-4-9
flyhigh69
Flight distance : 75079 ft
Did you happen to have any of the props, prior to the compass failure issue , smack any branches or anything where the props are stopped while motors are running? Sounds like it could be the ECS board. Good luck.
2018-4-11
MPA
No. But thanks for reply.
2018-4-12
