EMTDad
Flight distance : 247933 ft
...and yet another question... When I started up my Spark, everything seemed fine. Just as I manually started to take off, I got a "Calibrate IMU" message, so I powered it down and went into the IMU calibration. It took FOREVER (literally 30 mins). After everything was updated all of the sensors showed they were fine in the GO app. When I took off, the spark started to drift backward. (I had 15 satellites and was not in ATTI mode at THAT time). I corrected the drift and brought the Spark back to the starting position. It then said "ATTI" on the screen and took off forward, slamming into a building and then falling to the ground. When I picked it up there were a few scuffs on the top, but the main issue is that now there is a small chunk taken out of the camera lens. The damage to the lens does not affect the picture from the camera, but it is still upsetting considering this is the 2nd flight of my refurbished Spark. Has anyone else had this issue? |
