Flight data lost???
428 5 2018-4-22
HendrikJB
Flight distance : 2132792 ft
South Africa
I`m NOT a happy pilot now
Today I did 2 flights flying out more than 500m.  During these flights the connection was severed and I received an "aircraft not connected" error message.  That is not my problem but my problem is that when I was syncing the flight data only 27m and 252m was retrieved respectively.
Why has this happened?
2018-4-22
DJI Diana
Flight distance : 2408 ft
Hi, I'm sorry to hear about the issue that you are experiencing. Could you please change a flight environment where the GPS is good and no magnetic interference to try it again? Please make sure you have synced the flight records successfully. If there is any further issue, please feel free to let us know, we'll here for help.
2018-4-22
HendrikJB
South Africa
DJI Diana Posted at 2018-4-22 19:22
Thank you for your quick reply.
I did see that the connection frequency changed from 2.4GHz to 5.8GHz by itself.  I have now changed it back to 2.4GHz to see what happens.
2018-4-22
DJI Diana
HendrikJB Posted at 2018-4-22 22:46
Hi, for the auto channel mode, it will pick the one with the best signal quality. If you are in an open field without other WiFi interference it will most certainly stick to 2.4 GHz. But if you are in a built-up area with other WiFi networks around the preferred choice will be 5.8 GHz.
2018-4-23
HendrikJB
South Africa
DJI Diana Posted at 2018-4-23 00:24
Thank you.
2018-4-23
DJI Diana
You are welcome. Hope you have a great time on flying the drone.
2018-4-23
