fansb81208c1
Flight distance : 22841 ft
hallmark007 Posted at 2018-4-25 12:40
It’s not always the case that signal will continue to weaken, it just depends the area your flying over at that particular time, does it have higher interference etc, in ideal conditions your Mavic Pro can fly 4 miles under FCC , Mavic has a pretty reliable signal it can jump right back up from 3 to 5 once interference is gone.
Once you lose signal your aircraft will return home. Just two things to remember 1/ how much battery you have left, and even more important how much wind is out there, always particularly when testing distance make sure you start mission upwind, Mavic Pro is particularly slow into a headwind.
Thanks for the info. This might be a stupid question, but what is FCC? |
