william.barnhil
I went for a flight today, the 7th flight on this battery, and upon getting home after the session I placed the battery on the DJI charger only to see within an hour the charging lights change to the two center LEDs on solid. Well that's odd. So I look up some info online and see results like "battery fried". Tried to plug in the battery and Phantom to get info from the Assistant, and the battery causes the Phantom to restart over and over again until you turn off the battery. It will not stay on, so I can't even pull data from the Assistant. I plug in my second battery and all APPEARS well with that one (though I haven't attempted to fly again since finding this out).
This is the battery that came with the P2VP from a DJI Authorized Dealer (Barcode on bottom of battery: DJ070014102822688). All contacts on battery and P2VP are clean. As mentioned, the other battery I have appears to be working fine. The P2VP has never been connected to the Assistant before today so this isn't a failed upgrade. Charging/discharging has been in line with DJI recommendations. If anyone has any suggestions, I'm very much open to them. Thanks in advance.
