DMX_MLT
Malta
I assume that in the DJI GO4 App you press the Record Button and Start Recording. When you want to Stop press the Record Button again. There is Start/Stop Recording on Remote Controller or App Only, depends on what you use. There is No Auto Recording to the SD Card.
If you are using an SDCARD the real footage will be stored on it at the Resolution you choose, on the other hand, if you setup Video Cache ON, the phone you will have the actual backup footage in 720p just in case you need evidence if you have an accident and lose your Drone, but you need to Press the Record Button. Video cache is NOT AUTOMATIC, it will only cache video as you Record, it can store Audio too, where as the SD CARD Footage wont store the Audio.
Then with 3rd Party Programs like Premier Pro Video Editors, you can cut, edit, remove any sections (scenes) you don't want.
