battery charging
404 3 2018-5-1
Newday
I have an iphone 8 and was wondering can I plug the osmo mobile 2 using the cord that comes with it, and the bplug from the iphone into the wall?
2018-5-1
Newday
Osmo mobile 2, I want to charge the battery. I have the USB cord plugged into my, computer and it is charging slow. Can I charge by plugging the USB into an apple plug?  I would be using the plug I use for my phone and plug it into the wall?
2018-5-1
LouisP
Flight distance : 41952 ft
Newday Posted at 2018-5-1 15:59
Yes.. DJI recomends that you use a 2amp charger.. the computer is probably only supplying 1/2 an amp... the charger that comes with an iPad is over 2 amps.. that will work much faster.   When I first opened mine the battery was stone cold dead.. I plugged it into a computer for  a couple of house and it was still dead.. plugged it into a 2am usb charger and it finally started to take a charge.
2018-5-1
The Osmo Mobile 2's battery needs to be charged with the power cable, but you can use other chargers as long as the power voltage of the charger is 5V and the current is less than 2A.
2018-5-2
