Geebax
This effect is quite normal for a rolling shutter camera. While you cannot eliminate it, you can reduce the effect somewhat by using ND filters on the front of the lens to reduce the light coming in, then set the shutter rate to twice the frame speed. Other than that, the usual remedy is to slow down pans or side tracking shots as much as possible. |
