DJI Phantom 3 Standard - Antenna Broke Off - Will it affect flight?
1158 3 2018-5-16
fans2befe3fd
Just dropped the controller about 4 feet up and the antenna snapped off. I have not tried flying the drone after it broke, since I do not want it to affect range or give-out mid-flight.
Anyone know if it will operate the same with distance?
Also, if gluing it with gorilla glue will be an okay fix? Not looking to spend money for a new antenna since it's just the standard version.
Thanks!
2018-5-16
Mark The Droner
Flight distance : 2917 ft
I don't see an antenna cable.  What happened to it?
No, sir, you should not fly with that controler until you correctly fix the antenna.  In fact, you should not turn it on at all.  You risk burning out the transmitter.
Looks like you need to do an antenna mod.  Look at it as a good thing.  Do a little research and look at it as a fun adventure with lots of good times ahead.
Good luck
2018-5-16
ALABAMA
Flight distance : 10442687 ft
Good opportunity for Itelite to take up residence.
2018-5-16
DJI Thor
Flight distance : 13602 ft
It has the antennas in it. I suggest sending the drone in for repair. Please contact our support on the following page to start a case: http://www.dji.com/support
If you need accessories price checking first, you can click this link for further info: https://repair.dji.com/repair/price-inquiry
2018-5-16
