KedDK
Flight distance : 1133038 ft
Denmark
You sure should be able to do this.
With your index finger tap/poke on the very top above the DJI logo and swipe/drag the finger down on the screen, if only you see a narrow bar then tap that and repeat the down swipe.
You should get a box showing date/time, volume and brightness settings and some other icons, on top right there would be a gear like icon that when tapped bring you to the settings from where you can tap a wifi section.
If you can't get any of this, then try going one step back by the top left arrow that show on your screenshot and try from where ever that arrow bring you.
