KenDuke
Flight distance : 50837 ft
Seems like after the update, that DJI knows that there is a gimbal issue, but refuses to do anything about it.
You can press and hold a spot on your screen, till a blue dot appears, and then the gimbal moves just fine.
Make sure that when the AC does the startup process, the gimbal moves in all directions, and you don't hear a clanking type noise.
If you get the noise, one of the small screws on the gimbal has started to come loose, and the camera now is not centered.
I've tried many times, even DM'ing a message to DJI Susan, with no response. There is a video, I posted about this, on this website as well. Still no response to how to get this fixed.
The holding buttons C1 and C2 seems to do NOTHING for me.
Range after adding the newest firmware is also someone limited. Video breakup, and calls to return to home are common.
I'm not getting any ESC errors, but do get the message "Aircraft is warming up", and stays for quite a long time.
I've tried the fridge, and then cal. the IMU afterwards, and I still get this.
I'd like to see if updating to the firmware that fixes the ESC problem, will also fix this issue.
Thanks!
