Gala
Flight distance : 8035 ft
DJI Gamora Posted at 2018-5-23 08:42
Hi there, Gala, I'm sorry for the inconvenience that you have faced regarding with your concern may I ask have you tried to calibrate the gimbal camera? and also regarding with the SD card have you try to use different SD card just to isolate the issue?
Hi, thank you for your reply. Yes, I did calibrate the gimbal. The SD card its new and I also used it on my previous MA with no overheating issue. I dont have a seccond one but I am pretty sure that the card its good. Anyway I will try another one tomorow. What bothers me more is the gimbal issue as I need smooth movements while filming. Can you please confirm me if the latest firmware changed anything in gimbal behaviour? I tested my previous MA with 300 firmware and the up/down gimbal movement was smooth. |
