Sparkz71
Flight distance : 24259 ft
G'day.
I agree that the RTH procedure & options become confusing. It all depends on the distance to the home point.
1) 100 m +, RTH at pre-set altitude at 10 m/s without obstacle avoidance. Aircraft returns to hope point.
2) 100 - 20 m, RTH at pre-set altitude (at 3 m/s ???) with obstacle avoidance. Aircraft returns to hope point.
3) 20 - 3 m, RTH at current altitude disabled. 3 m/s ??? with obstacle avoidance. Aircraft lands where it is.
4) 20 - 3 m, RTH at current altitude enabled. 3 m/s ??? with obstacle avoidance. Aircraft returns to home point.
5) 3 m or less, Aircraft lands where it is. I believe the aircraft can be moved prior to accepting the final landing prompt.
6) Note: The aircraft will stop ascending & immediately return to the home point if you move the throttle stick, if the aircraft reaches 20 m altitudes or beyond during RTH.
I guess the use of the various options may depend on where the aircraft is flying. Activating RTH above or below trees, bridges, near water, power lines or any other obstacle may require different altitude settings. If flying low under a tree 10 m away, you may not want the aircraft to ascend 2.5 m & hit a branch. It may be safer to turn off RTH at current altitude & land under the tree. If flying above a tree or water the reverse would apply.
The RTH procedure is in the tiny user manual. Fortunately there is a pdf version available. https://dl.djicdn.com/downloads/ ... 0Manual%20V1.6-.pdf
Page 14 explains under 4.b. - when the aircraft is between 3 m & 20 m from the home point it will land automatically with the RTH at current altitude option disabled (default setting).
When RTH at current altitude is enabled the aircraft will return to the home point at current altitude. If below 2.5 m is will ascend to 2.5m then return home.
If the aircraft is within 3 m from the home point it will land where it is.
Good luck. I still get confused! |
