fans28966f2c
DJI Natalia Posted at 2018-5-25 14:15
Thank you for raising this concern and I apologized for this inconvenience. May you share it with me the exact issue that you are having on your Phantom 3 Professional? Thank you.
Hi Natalia,
The problem: After not using my P3P during the winter months, I got it out, charged all the batteries and fired it up. The controller and the aircraft are not communicating.
The controller has a red light showing next to the white battery lights. My iPad mini, with the latest DJI Go app will not communicate with the controller either.
The latest firmware is loaded on the aircraft.
Packet: P3X_FW_V01.11.0020.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
When the aircraft battery is switched on, after the usual beeps, the yellow lights flash continuously.
I hope you have some ideas about this!
-Tom
