Axeli
Flight distance : 339416 ft
Czechia
"You can view the current compass interference in the "Main Controller Settings" --> "Advanced Settings" --> "Sensors" section of DJI GO. The colored bars should be in the green (Excellent) range when the Mavic is in a location that is away from magnetic influences. If the bars are in the red (Poor) range or close to it, move the Mavic to a different location and check again. If the compass interference is still in the red (Poor) range or close to it, the compass could need calibrated or it could be magnetized/damaged."
Also, you should check how that bar goes if you move gimbal up/down. Let us know |
