jwhite
Ok, so I ended up just taking it out but unfortunately it was far too windy to fly the P3 today maybe it will slow down later. But, I still did some tests and messing around to look for a fix with the remote.
Photo 1: I noticed right away when I started it I had almost not remote signal again. So, this time I decided to reconnect the remote to the P3 through the app (start the reconnect, click the link button on side of P3). After I did that, I had full bars connection with remote! (YAY!!!!!!)
Photo 2: After having (hopefully) fixed the connection to remote issue just by re-establishing the connection, I wanted to find out if it still worked from a distance. Since it was so windy out, I really couldn't get an aerial test, so I walked as far as I could and even put 2 very large metal buildings in between myself and the drone that was also on the ground. I definitely lost video connection, which I figured would happen, but this time I never lost connection with the remote, which is what caused most of the issues from the day before. I'm hoping things are fixed now but I really won't know until weather gets a bit better to really try the signal test in the air.
Photo 3: just a pic I snapped of the P3 battling the wind. Kept it hovering a bit to see how well it did. Was cool to watch, definitely won't be sending it into the air though as it was getting pushed around quite hard on and off.
