JJBspark
Flight distance : 12445630 ft
Dewey3 Posted at 2018-6-1 02:57
Greetings. You may already know this, but if not... the quotes (") are used to preserve the path for names that are outside of the legal DOS 8.3 file names. You would encase the entire path in quotes if any part of it is outside of DOS' standards. An example is if you wanted to load the foobar.ini file located in Program Files\This Path\foobar.ini, instead of using \PROGRA~1\THISPA~1\foobar.ini, you could use "\Program Files\This Path\foobar.ini". You can drop down into a command prompt and use the change directory (CD) command to see how the quotes work in action. Sorry for getting away from the original topic, but I am just hoping that this would help with your great FRAP contribution to the community.
Thanks, the quotes i used here to indicate a space character. FARP doesn`t use the " " as it is.
I have no knowledge about the converter tool, so the quick solution is a) not use space characters in the path en b) stay close to the root of a drive-letter.
Cheers JJB |
