Take Off Error : Check imu and motor ERROR
13467 21 2018-6-2
C4lifer
Flight distance : 54577 ft
my mavic air will not take off ... motors power up then ramp up to max speed unit never leaves ground then i guess fail safe kicks in motors shut down...WHAT DO I DO??? ((
2018-6-2
Wachtberger
Flight distance : 261509 ft
Refresh your firmware as first step. I have posted the download link for DJI Assistant in response to your other post. If problems should persist, please post screenshots of the messages you are getting.
2018-6-2
HedgeTrimmer
Motors go to full speed and it won't take off.  Sounds like props are on reversed and it is trying to shove itself into Earth.
2018-6-2
dronist
HedgeTrimmer Posted at 2018-6-2 07:11
  How may shots did you have today?
2018-6-2
HedgeTrimmer
dronist Posted at 2018-6-2 13:08
Not enough!
How could OP's drone sit on ground with its motors / props turning at full speed, to point  fail safe finally kicks in and shuts motors down?  Unless said drone is strapped down to ground.  That puppy should have launched into air, even if it turn turned somersaults and smashed into ground.
2018-6-2
FlyDK
Flight distance : 1636286 ft
Denmark
"motors power up then ramp up to max speed unit never leaves ground"
That sounds like not possible.!
2018-6-2
HedgeTrimmer
FlyDK Posted at 2018-6-2 13:58
New feature with upgrade?
Reverse motor to simulate helicopter's collective, for those quick downward escapes away from attacking birds.
2018-6-2
dronist
HedgeTrimmer Posted at 2018-6-2 13:54
Not enough!
Maybe few more shots and you will make more sense  .
Props can't be installed in reverse. The obvious is some internal malfunction or he is trying to fly next to a runway...
2018-6-2
HedgeTrimmer
dronist Posted at 2018-6-2 15:22
Okay, I thought props were similar to Mavic Pro.  It was possible to get pairs reversed.
CW props on CCW motors and CCW props on CW motors.
2018-6-2
HedgeTrimmer
Joking aside, Are you certain props are going to max speed, and not simply idling waiting for you to throttle up or command to throttle up is not being performed?
2018-6-2
WebParrot
Flight distance : 23625 ft
HedgeTrimmer Posted at 2018-6-2 15:11
Hurray!  We're finally getting inverted flight!  (Now we can mow, just like the Heli pilots.)  ;-)
Screen shots would help.
2018-6-3
DJI Diana
Flight distance : 2408 ft
Hi, sorry for the late response, may I confirm that have you solved the problem or not? If there is any further issue, please feel free to let us know, we're glad to help.
2018-6-3
C4lifer
Yes problem solved simple miss appropriation of the props they can be installed incorrectly
2018-6-3
fansc0d5288c
Malaysia
Same goes to me. What should i do. Please help me ☹️
2018-11-6
djiuser_tOsdUKj95JoH
DJI Diana Posted at 2018-6-3 20:31
Can you please provide some information as to how we are supposed to identify the correct order in which to install said propellers with? To the my best knowledge it isn't documented or intuitively easy to find. considering that it actually prevents takeoff... also not sure what the sliders are used for.
Thanks
2019-6-9
DJI Diana
djiuser_tOsdUKj95JoH Posted at 6-9 04:10
Thanks
Hi, sorry for the troubles you had. May we know what aircraft you're referring to? Thank you.
2019-6-9
Ninos Patto
Sweden
Hi guys.. I'm new here and I have an issue..
Few months ago I had an incident with my drone (Mavic Air).
The drone crashed against a tree and down to the ground.
The arms broke and I contacted DJI to repair it.
When it came back, it wouldn't take off. The propellers went on full speed, but wouldn't take off.
I contacted DJI again and they asked me to send it back.
When I got it back the second time, it still wouldn't take off.
3rd time is a charm. I contacted DJI again and they said I needed to change the propellers and no need to send it back to them.
Said and done.. New propellers.. Still no take off.
A yellow message pops up saying: "Takeoff Error. Check IMU and Motor".
I tried to update to the lastest firmware and recalibrating both the IMU and the compass.. The drone still woun't take off..
Please help me.. I'm on the verge of throwing it against the wall..
Thanks in advance..
/Ninos
2019-8-16
delanytime
Hi All,
Good thread.
I'm receiving the same error as Ninos Patto.
Similarly, returned my drone to DJI - got it back and it still wouldn't take off (frustratingly at the start of a wedding - should have tried it first). Keep getting "Takeoff Error. Check IMU and Motor".
All help appreciated
Thanks
2019-11-20
djiuser_fHm8SqSS1Dva
im having the same issue just wont take off.   same error message. tekeodd error check IMU and compass
2020-2-6
fans549095b9
Colombia
I had the same problem. I fixed it changing the propellers and being careful to put the ones with the white line in the motors who has a white mark.
2020-6-1
kmccallister
I have the same problem with my spark, but when i take the rotors off to test it so it doesn't just run away, it gives that same issue.  tried calibrating the IMU and compass, checked for firmware updates, but nothing seems to help.
2023-1-23
Vofas
Flight distance : 200853 ft
Russia
kmccallister Posted at 1-23 15:18
Propellers installed correctly? In accordance with the color labels?
2023-1-23
