Matioupi
Flight distance : 922569 ft
Hello,
I'd like to know where the GPS antenna is located internally with the 5.5 and 7.85 CS.
Those device may be used with flipped screen and depending on the location, the actual orientation of antenna may be quite sub-optimal (e.g. if antenna is facing to ground)
There are also a large variety of mounts, including some with a metalic bracket, that may reduce antenna received signal.
Having this info would be nice to make obtimal choices. Actually on a 5.5CS mounted with DJI Spark/Mavic mount bracket, I always have the feeling that the GPS reception on the CS is quite poor.
Regards
