DMX_MT
Malta
Hi Kite,
I notice you are from France.
OTG works like this - Phone -----> OTG Cable -------> Remote ((( <-------- WIFI ------------> ))) Spark
There are 2 Types of Wifi Power between Remote and Spark - One is called CE Mode (For Europe) and other is called FCC Mode (For USA)
Now the Problem here in Europe is that Spark use 5.8GHz to connect from Spark to Remote and 2.4GHz from Remote to Phone
The 5.8GHz Power in CE Mode is very bad, meaning Low in Power and this results in a Very Short Range
OTG is used for a more stable connection between Remote and Phone, imagine a Cable Internet vs Wifi Internet. Cable Internet has a Physical Connection via Cable. Meaning more Stable than an Air Signal.
If you use OTG and force a 2.4GHz connection between Spark and Remote thats the best you option, 2.4GHz is a Longer Wave and will give you a bit more power for us in Europe using CE Mode. Then only draw back is that Channels then to be more busy in 2.4GHz as home wifis, phones, etc... mostly use 2.4GHz here in Europe. So in Urban Areas its a bit hard to use 2.4GHz.
Here are some Power Comparisons to see difference between CE and FCC Mode:
The transmitter power is the same for both. Antennas and encoding make the difference.
The specs say: Spark:
Transmitter Power (EIRP)
2.4 GHz
FCC: ≤26 dBm; CE: ≤18 dBm; SRCC: ≤18 dBm; MIC: ≤18 dBm
5.8 GHz
FCC: ≤28 dBm; CE: ≤14 dBm; SRCC: ≤26 dBm; MIC: -
The dBm in CE is ridiculous !
The dBm between FCC and CE at 2.4GHz is 8dBm that makes a difference from EC - 500m to FCC - 2000m range.
The dBm between FCC and CE at 5.8GHz is 14dBm that makes a difference from EC - 300m to FCC - 2000m range.
If you have problems let me know as this is a Complicated Topic.
