Neal McGuire
Thank you for your help. I checked out the link and have the following concerns.
1) We were attempting to fly at 4551 Anthony Lane, Farmington Mo. Per FAA charts this is a class E airspace with a base of 700ft. So a waver should not be need in this area. The link shows it as an authorization area, that we should be able to override. We were not able to do that.
2) The link also shows a restricted area over the Farmington Correctional facility. The problem is that the restricted area on the map is not over the correctional facility. It is about a km north of the facility. You can see the facility on the map, and it is clear that it and the restricted area do not line up.
Thanks
