Ridg
Flight distance : 232306 ft
Bokepacha Posted at 2018-9-12 00:47
Hi Ridg, One questionÑ
Why toning? Shouldn´t that just break the regular HDR_ I use CC too for HDR pics, but I take the default RAW images and import them into the HDR script program photoshop has. If I apply an change with cameraRAW before that, it breaks the HDR.
It's the option on the HDR Pro dialog (not changing the RAW pre-merge).
Essentially you're using ACR on a 32bit 'RAW' image that's been generated from the sources, if you choose 16 or 8 bit then you can use the built in presents or generic HDR settings (option un-ticked), local adaptation, exposure, gamma etc Either method is perfectly fine however I prefer using ACR
