No outcoming wifI signal from DJI spark
380 11 2018-6-16
djiuser_DnDpEAHh3wQ8
Flight distance : 1106 ft
Belgium
Hi! I'm having issues with my spark. When turning on the device it doesn't send out a wifi signal. I tried another battery and so on, but still no change.
Does someone know what the options are to solve the problem?
Cheers
2018-6-16
DMX_MT
Malta
Try resetting the Wifi to Factory Setting first -
2018-6-16
DMX_MT
Malta
If you are using a Remote Controller -
2018-6-16
DMX_MT
Malta
Also this may help you -
2018-6-16
DMX_MT
Malta
Give your Phone a Restart, sometimes it helps. Give a Restart to the Spark too.
I would give the Spark's Wifi a Factory Reset First. After the Spark has been powered on, press and hold the power button for 9 seconds (or until you hear 3 beeps) to reset the Wi-Fi.
Are you using the Phone alone to connect or the Phone + Controller ?
Here you have explained the Beeps when you hold the Spark Power Button to change the Type of Connection you want -
After the Spark has been powered on, press and hold the power button for:
  • 3 seconds (or until you hear 1 beep) to link the remote controller to the Spark
  • 6 seconds (or until you hear 2 beeps) to disconnect the remote controller (so you can enable virtual joysticks on the Phone)
  • 9 seconds (or until you hear 3 beeps) to reset the Wi-Fi
2018-6-16
DJI Paladin
Flight distance : 318 ft
Hi, Our apologies for the inconvenience. May i know if you want to link it directly to your remote controller or you want to control the aircraft using your mobile device only?
2018-6-16
Belgium
@dmx_mt thanks
2018-6-16
Belgium
I  tried to connect it to my phone, but nothing worked out.
2018-6-16
Belgium
DJI Paladin Posted at 2018-6-16 04:54
Only mobile device
2018-6-16
DMX_MT Posted at 2018-6-16 04:51
https://www.youtube.com/watch?v=CuACnyi-l-k
It worked out. Thanks! Appreciate it alot
2018-6-16
DJI Paladin
djiuser_DnDpEAHh3wQ8 Posted at 2018-6-16 07:17
Hello, I'm happy to hear that. Please let us know if you still have other concern. Enjoy your spark and have a safe flight.
2018-6-16
DMX_MT
Malta
You are Welcome.
2018-6-16
