Video Distorting on screen
366 6 2018-6-17
djiuser_sH3YCJZsT9HE
I have tried formatting 2 SD cards, attaching RC through USB Cable to Phone, then swithced to tablet, but I am getting a distorted view and serious lag in the video on my screen. The video records fine, I just cannot see what I am recording, any suggestions? Thanks in Advance Nick
2018-6-17
Now I am getting Calibrate the Vision Sensors with DJI Assistant on PC or MAC for Higher Accuracy. What is this? Never have downloaded anything for PC, just DJI Go APP for Phone.
2018-6-17
DJI Tony
Hi, we do apologize for the inconvenience, I would recommend downloading the DJI Assistant 2 on your computer and re-calibrate the sensor, I would advise using a 14-inch monitor or more and the video resolution should be set in default mode for a better sensor calibration. Please see the link for you to download the application. Thank you.
https://www.dji.com/mavic/info#downloads
2018-6-17
davidmartingraf
Flight distance : 108805200 ft
djiuser_sH3YCJZsT9HE Posted at 2018-6-17 14:35
I had the exact same problems with my Mavic Pro. I uninstalled and reinstalled the software, finally re-calibrated the vision sensors through the App and re-calibrated the RC and re-flashed the firmware of the Mavic Pro. Finally, this all for the moment seems to have corrected the issue, but it'll be a wait and see strategy.
2018-6-17
HedgeTrimmer
davidmartingraf Posted at 2018-6-17 15:09
Any idea as to what might have started the problem(s)?
2018-6-17
davidmartingraf
HedgeTrimmer Posted at 2018-6-17 15:47
I can only say the latest firmware that went into effect. I hadn't flown since before the updates and following them is when I noticed the problems?
2018-6-17
What is reflashed Mavic Firmware? I have done everything, re calibration on DJI Assistant, tried formatting SD Cards, tried different cables, and still getting distorted screen.  I have over 300 hours of flight time with same phone, same SD Cards, and this just started 3 days ago...
2018-6-18
