No Image Transmission and No Gimbal Status
579 5 2018-6-30
fans521658b7
Flight distance : 139626 ft
Several months ago I pulled out the P3 STD to get it ready for a shoot and install any updates.  The first thing I noticed was no image was showing on the mobile device.
Phantom 3 STD
Firmware V1.09.02
DJI Go v3.1.42
SD card: SanDisk Ultra 8gb
Symptoms:
- No Image Transmission with SD card in or Out
- Gimbal Status in DJI Go app indicates "Gimbal Disconnected"
- Remaining SD card Capacity not showing and no option for reformat in DJI app.
- SD card has no succesful install file after running through start up
What works:
- Starts up and runs through system check with no problems
- RC has full control of camera movement and controls
- P3 Gimbal status light Green
- P3 green slow blink, and link button green
What I have tried:
- Tried start up in different areas to ensure it wasn't an interference problem.
- reformated sd card on computer and dropped in firmware v1.09.02.  ** After running the firmware in the P3 I checked the log file on the card and it was not there
- Conducted gimbal calibration from DJI Go app
- Relinked the controller
- unistalled and reistalled app
- tried 3 different mobile devices to run app. Iphone 6, X and Ipad mini.
I ran through this so many times my head hurts so I am sure I missing something. If anyone can give me a direction to go is would be appreciated.
2018-6-30
DJI Gamora
Hi thanks for reaching DJI Forum, apologies for any troubles you had. May I suggest to download the app to an android device. Below are the list of mobile devices you can choose from.
2018-6-30
fans521658b7
I don't have access to an android device at this time but I will look into that option.   In the meantime I will still try and figure out what happened since I know that all the devices I tried are compatible and prior to updating worked fine. It just doesn't make any sense to me and I like to believe its something simple on my end and not the P3 or mobile devices.
2018-6-30
ALABAMA
Flight distance : 10442687 ft
Try unplugging the cable pin on top of gimbal.  Also, check ribbon cable for nicks or broken places, and all connections.
2018-6-30
Rvrrat14
Flight distance : 655932 ft
I guess I’m missing something.   OP has IOS devices and DJI mod recommends trying a droid?????
I have IOS devices, too, and a P3A.  Hope others post their findings here.
2018-7-2
Peterx
Flight distance : 1499708 ft
Turkey
May be is the post from the moderator strange ,but i could do all operations and upgrades with an Android device with success.
My flights i have done with both iOS and Android devices..
2018-7-5
